Alt 24.08.2013, 12:27   #7
Peter, wenn double Lock 'eingefroren' im RM ist, dann geht es nicht mit der Notentriegelung, das Schloss ist in double lock blockiert. Er macht es ja schon richtig, dass er versucht, die Batterie voll zu entladen, vielleicht tut sich dann ja was am RM, oder halt nicht.
In USA haben deshalb schon einige das Relaismodul modifiziert und das double Lock entfernt, ich zitiere:
Relay Module mod (disable deadlocks)
The "component" is the resistor connected across the coil, as shown in the schematic (pg 5126-02)of the ETM. Its function is to dissipate the energy stored in the coil, when the coil is turned off.
We want to cut the trace to the coil, so it can never again pull the contacts in. Cutting the trace to the resistor is optional - it will make no difference.
Here's the acid test: Connect 12V across pins 4 and 15 of the BLK connector X258 and see that Relay #10 snaps in. Then cut your trace(s) and see that the relay does not operate. Mission accomplished!
.... can share some experience with Deadlocking.
Print page 5126-02 to 04 at Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.e38.org/e32/e32_88_etm.pdf
Notice that there are 2 motors inside the 4 Door Lock Motors M12 - 14, and only 1 motor inside the trunk and fuel flap lock motors M16 and M17.
The extra motor, driven by the BLK wire at pin 1 of the lock motor connectors, is the actual Deadlock function. It sets a pawl that prevents the other motor from unlocking the door. It is supposed to be Deadlocked by the alarm system, and then Deadlock-Released 30 minutes later, or when a key-holder unlocks the passenger door.
It is a beastly thing. I recommend cutting the pin 1 BLK wires, so the Deadlock can never trigger again.
Perhaps your rear door locks got a Deadlock pulse, and never received a Deadlock-Release pulse. This is strange because all 4 door motors share the same BLK Deadlock wire. Of course the front doors are privileged because they have key locks, which the rear doors lack. Perhaps the Battery was weak when the last Deadlock-Release pulse was sent, and the rear doors did not fully execute this command.
I will do some experiments tomorrow and post my findings. I'm certain that you can send your own Deadlock-Release signal.
Since electricity caused the problem, it would be nice if electricity could fix it!
Here's what to do: Move the driver's seat fully forward so as to expose the B pillar trim. Remove this trim and locate the loom of wires that runs to the rear of the door connector X273. See pg 7100-12 Fig 2 and pg 8500-07 for the X273 pin positions.
In the loom there are 3 wires of the same diameter - BLU, WHT, BLK. Locate the BLK wire that goes to pin 11 of X273 and cut it a few inches from X273. Tape up the cut BLK wire that disappears under the floor. Strip off a bit of insulation from the cut BLK wire that goes to X273.
Now you will need a 12V source - a booster battery pack, or a battery charger, say. Measure the voltage across its leads to be sure that 12V is available - some chargers will not produce any voltage until they sense that a battery is connected with the proper polarity. You could even use jumpers from another car, but be certain the two chassis do not touch! You cannot use your own car's battery, because we need -12V rather than +12V.
Connect the POS battery lead to the car's chassis anywhere you can find bare metal. Now briefly touch the NEG battery wire to the bare BLK wire. This will Release the Deadlock pawl and you should be able to open the left rear door in the usual ways.
Tape up the BLK wire (Do NOT splice the 2 BLK wires back together!) and replace the B pillar trim.
Repeat this job for X274 in the passenger side B pillar.
BTW this works because the RM is grounding all 3 of the central locking motor wires - BLK, BLU, WHT. The BLK wire is not our friend. It's only function is to cause us woe.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.bimmerboard.com/members/s...le%20004_1.JPG
Haubenentriegeung geht so besser. Grill neben dem linken SW "ausbauen". Dann kann man von unten an den richtigen Hebel fuer die Notentriegelung kommen an der Haubenverriegelung.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) ImageShack® - Online Photo and Video Hosting
Bei mir war letztes Jahr das Plastikteil defekt an diesem Schloss, da kannste ein Loch bohren und am Bowdenzug ziehen wie Du willst, aber das Schloss/der Haubenverschluss geht nicht auf.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.e32-schrauber.de/bmw/s-zke.htm
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.davintosh.com/2010/02/27/...a-bmw-e32-fun/
hier zum besseren Verstaendnis von der ZKE IV was
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.unofficialbmw.com/images/lock.pdf
EWS Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.computersolutions.cn/blog...02/BMW_EWS.pdf
Was jetzt genau passiert, wenn das Relaismodul keinen Saft mehr bekommt, kann ich nicht sagen.
Geändert von Erich (24.08.2013 um 12:54 Uhr).
Motorhaube läßt sich nicht öffnen 750zxr740il BMW 7er, Modell E38 10 19.03.2012 00:22
Elektrik: Auto läßt sich nicht mehr öffnen mgbRecords BMW 7er, Modell E38 3 20.04.2010 13:55
Karosserie: Motorhaube läßt sich nicht mehr öffnen. Knut Helge BMW 7er, Modell E38 10 21.10.2009 20:15
Fahrzeug läßt sich nicht öffnen. nugget1711 BMW 7er, Modell E32 22 31.05.2009 05:26
Fahrertür schließt, aber läßt sich nicht mehr öffnen uk735 BMW 7er, Modell E32 2 21.05.2002 11:36
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:39 Uhr.
