Alt 15.03.2018, 00:01   #8
Hier hat mal einer fuer seinen E31 850 eine Moeglichkeit gefunden, im Ersatzteilkatalog gesucht, und Benzinschlaeuche mit Biegung gefunden, die viel billiger sind, die man dann in Teile passend schneiden kann:
Tackling most overlooked fuel hoses on the entire car, the fuel filter assembly hoses. Most owners never change them and just reuse them after changing fuel filters, why? Because to change all the hoses in that assembly cost almost $100. The molded pre bent hoses on top of the fuel filters are $30 each! I did some research and I am gonna show you how to get the same BMW molded hoses and do the entire job for under $30!
I searched the BMW data base and found 1 fuel line that we gonna use to make 3 of the hoses that we need. BMW # 13901743626 It has a perfect U and two Ls that are exact fit. You will also need to buy one BMW # 13311288284 But it's cheap $12. These two hoses is all you need for this job.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://uploads.tapatalk-cdn.com/201...7cc8efbebf.jpg
Cut out the U and L shape on each side of the hose.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://uploads.tapatalk-cdn.com/201...e8ef6c5ea8.jpg
Result is exactly what we need! Perfect fit!
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://uploads.tapatalk-cdn.com/201...f475c2cc43.jpg
Next one of the bottom hoses, use the second L in the middle. I am usually not a big fan of extensions but for the sake of staying under $30 a quick trip to Lowes and $2 bucks later I got a brass coupler. Use the rest of the hose to extend. Cut to the length of the old piece. That's it! Now we have all brand new hoses.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://uploads.tapatalk-cdn.com/201...055c80eeb1.jpg
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://uploads.tapatalk-cdn.com/201...28ae832c41.jpg
Formschlauch AKF (13901743626) EUR 16.16 , verbaut in E36, Z3
Geändert von Erich (15.03.2018 um 00:17 Uhr).
Neid ist die aufrichtigste Form der Anerkennung Speedy_1304 BMW 7er, Modell E65/E66 10 16.08.2015 21:45
E9x Rep. Anleitungen in digitaler Form gesucht FN High Power Autos allgemein 1 11.01.2011 23:30
Suche Bilder vom 7er-Form Aukleber! Laafer BMW 7er, Modell E32 4 09.11.2008 19:38
Eierlegende Wollmilchsau in e23 / e32 Form! johnnyr Suche... 0 31.10.2004 17:23
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:52 Uhr.
