Alt 12.07.2025, 07:59   #1
Andrew1Q
Fahrzeug: BMW E32-735i (02/1990)
Yes I did test in E9 version without EML if someone could write me what is measurement in E7 or E9 version with EML ?
Should connection be made same as in EML ? Pin 21 of the TCM is the engine speed signal and fuel pump isn’t the engine speed but it’s fuel pump speed.
EML version TCM pin 21 engine speed signal takes signal from the engine ECU pin 6. Could someone measure what is voltage at the pin 6 of the engine ECU when the engine idling at RPM750 ?
Vehicle with EML the pin 21 of the TCM takes signal from the engine ECU pin 6 and vehicle without EML the TCM takes signal from fuel pump. I would like to know what is difference in voltage. E32FAN in Quebec can test it his car with EML.
Geändert von Andrew1Q (13.07.2025 um 07:56 Uhr). Grund: EML
Andrew1Q ist offline   Antwort Mit Zitat antworten
E32-Teile: Getriebesteuergerät Beat Suche... 4 31.05.2015 22:17
Getriebesteuergerät hartlb BMW 7er, Modell E38 11 05.04.2015 16:59
E32-Teile: Getriebesteuergerät bmwfreak88 Suche... 2 10.06.2009 18:55
Elektrik: Getriebesteuergerät 17er Schlüssel BMW 7er, Modell E32 3 14.06.2006 13:41
Elektrik: Getriebesteuergerät Wolf730 BMW 7er, Modell E32 4 16.09.2005 19:24
Alle Zeitangaben in WEZ +1. Es ist jetzt 18:11 Uhr.
