Alt 27.11.2004, 15:37   #1
KJ750IL
Benutzerbild von KJ750IL
Standard Suche Pinbelegung vom DSP Verstärker!
Ich suche die Pinbelegung des DSP verstärkers nicht von dem Stecker mit den Lautsprecheranschlüßen sondern von dem mit den elektrischen anschlüßen!
danke
mfg -=WB750iL=-
Alt 27.11.2004, 16:49   #2
AlexanderStuttgart
Benutzerbild von AlexanderStuttgart
Fahrzeug: F01
Top! Was hast Du denn vor?
2000 DSP Premium Sound connector information
The pinouts for the 15 pin connector are:
PIN - CONNECTION
1- Sub 1 +
2- Sub 2 +
3- LH Rear loudspeaker + (Touring LH rear speaker ground)
4- Radio on/antenna signal
5- RH rear loudspeaker + (Touring RH rear +)
6- Sub 4 -
7- Sub 3 -
8- Terminal 30 connects to Fuse 56
9- Sub 1 -
10- Sub 2 -
11- Touring LH rear +
12- Touring RH rear -
13- Sub 4 +
14- Sub 3 +
15- Terminal 31 connects to Ground Point
The pinouts for the 18 pin connector are:
PIN - CONNECTION
1- Not used
2- Low freq. negative (-) signal - Transceiver/charging electronics
3- Not used
4- Not used
5- I-bus Signal Line - Splice X18344
6- Not used
7- Not used
8- RH front speaker - Connects to Radio
9- LH front speaker - Connects to Radio
10-Not used
11 Low freq. voltage (+) signal - Transceiver/charging electronics
12-Not used
13-Telephone mute signal - Transceiver/charging electronics
14-Not used
15-Telephone ON signal - Transceiver/charging electronics
16-Not used
17-RH front speaker + - Connects to Radio
18-LH front speaker + - Connects to Radio
The pinouts for the 26 pin connector are:
PIN - CONNECTION
1- LH front woofer +
2- LH front woofer -
3- Not used
4- RH front mid-range -
5- LH front mid-range +
6- Not used
7- Not used
8- Not used
9- RH front mid-range +
10-LH front mid-range -
11-Right rear mid-range speaker/tweeter +
12-RH front tweeter +
13-RH front woofer +
14-LH front tweeter +
15 LH front tweeter -
16-Left rear mid-range speaker/tweeter -
17-Not used
18-Not used
19-Left rear mid-range speaker/tweeter +
20-Not used
21-Not used
22-Not used
23-Not used
24-Right rear mid-range speaker/tweeter -
25-RH front tweeter -
26 RH front woofer -
AlexanderStuttgart ist offline   Antwort Mit Zitat antworten
Alt 27.11.2004, 16:52   #3
warp735
Mr. Diesel
Benutzerbild von warp735
gut das wir beim thema sind
hi alex..
wenn ich ne endstufe für nen sub anschliessen möchte, wo und wie häng ich die am besten dran. was brauch ich alles?
mfg Benni
Alt 27.11.2004, 18:26   #4
AlexanderStuttgart
Fahrzeug: F01
Standard ;)
Hallo Benni,
einen Sub schliesst Du folgendermassen an:
Du benötigst einen Verstärker mit einem high-level Eingang - also einen Verstärker, in dessen Eingang Du ein verstärktes Signal einspeisen kannst. Diesen Stereo (es ist immer ein Stereo Eingang am High-Eingang) Eingang schliesst Du nach obigem Bild und Tabelle folgendermassen an den DSP an:
An den 15 pin Stecker - das ist der Grösste von allen 4 Steckern des DSP:
Pin1- Sub 1 +
Pin6- Sub 4 -
Pin9- Sub 1 -
Pin13- Sub 4 +
Also einmal links und einmal rechts. dann noch den remote Anschluss des Sub-Verstärkers an:
Pin4- Radio on/antenna signal
dann noch plus/minus an den Sub-Verstärker - schon geht´s - achja: den Sub-Verstärker brückst Du dann noch als Mono-Endstufe (mit Stereo-Eingang) und schliesst so den SUB-Bass an.
Ps.: schau´s Dir am 19.12. in Leonberg an
Alt 27.11.2004, 18:48   #5
KJ750IL
Hallo alex,
Danke für die Pinbelegung!
Hast du erfahrungen mit einen Hi-Low Adapter gemacht?? Ist das nicht sogut als wie gleich eine Endstufe mit Hi Leveleingang???
Ist es nicht besser wenn man die an die Pins von den vorderen Lautsprecher das Signal nimmt? Steht in einen anderen Thread!!!
danke
mfg -=WB750iL=-
Alt 27.11.2004, 19:54   #6
AlexanderStuttgart
Fahrzeug: F01
Standard Wb!!!
Also hör: Du schliesst einen SUB an - SUB heisst U.N.T.E.R.!! in den Türen vorne hast Du keine SUB´s, sondern Kickbässe - und die haben auch Frequenzen über 100Hz - aber nur Frequenzen unter 100Hz lassen sich keiner Richtung mehr zuordnen - wenn Du die vorderen Kickbässe abgreifst, dann hast Du keinen reinen Stereoeffekt mehr - und nochwas:
Bitte frag nicht immer gegen - ich hab keine Lust,mir die Finger wundzutippen,nur,weil Du es nicht glauben willst
Also believe: Nur Abbriff an den SUBs der Heckablage sollen für den SUB im Kofferraum genutzt werden - und ausserdem: den Frequenzgang des SUB-Verstärkers so einstellen, dass er Frequenzen über 80Hz wegfiltert.
Das ist der Vorverstärker - den musst Du dir aber selbst zusammenlöten
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Vorverstärkerbausatz von Conrad
DIN-CYNCH-PEGELANPASSUNG - BAUSATZ
Artikel-Nr.: 192708 - 13
Preis nur 17,95 EUR
Stück
Die genormten Signalpegel von DIN-und Cinch-Buchsen sind unterschiedlich. Zum Überspielen (von DIN auf Cinch/oder umgekehrt) ist es erforderlich, die Ein- und Ausgangspegel entsprechend anzupassen. Eine optimale Übertragungs-Qualität ist somit gewährleistet. Den Ein- und Ausgangspegel stellen Sie über Trimm-Potis individuell ein.
Technische Daten: Betriebsspg.: 12 bis 15 V/DC · Stromaufnahme ca. 15 mA · Verstärkung des DIN-Pegels: 7 fach · Abm. 120 x 82 mm.
Bausatz mit ausführlicher Bauanleitung.
Hier noch ein Bild - das in silberne Aluklebefolie eingepackte Kästchen beinhaltet das CONRAD-Vorverstärkermodul; es schliesst an die TAPE-Leitung in´s BM-Radio an und ist Eingangs an den DVD angeschlossen:
Alt 27.11.2004, 20:34   #7
KJ750IL
Hallo Alex,
Also erstmal danke fürs viele Tippen muss dich aber leider noch was Fragen und zwar, was muss man an dem Vorverstärker löten damit er geht????
danke dir
mfg, -=WB750iL=-
Alt 27.11.2004, 20:43   #8
warp735
Mr. Diesel
mensch du scheinst ja wirklich nicht der hellste zu sein!! eigentlich lese ich deine beiträge schon garnicht mehr!
warum versuchst du an deiner eieruhr zuschrauben wenn du ja offensichtlich nicht mal weißt wie man von "P" auf "D" schaltet...???
alex hat doch geschrieben das es sich um einen BAUSATZ handelt, was soll also deine blöde frage?
nix für ungut, mfg Benni
Alt 27.11.2004, 20:55   #9
TomS
Hoher Priester
Benutzerbild von TomS
Fahrzeug: E-Macan 4S, Cooper S
@WB750iL
wie ich Dir ja schon paarmal auf Deine U2U-Fragen geantwortet habe:
Bei DSP ist das alles anders als ohne.
OHNE DSP greift man an den Türen dran als einfachste Lösung
MIT -> wie oben geschrieben
@all
Endstufen mit Hi-Eingang gibs z.B. von Crunch ein paar ganz anständige.
Alt 27.11.2004, 21:07   #10
AlexanderStuttgart
Fahrzeug: F01
Standard kicher - nicht aufeinander rumhacken - und nicht vergessen:
... alle Fragen führen schliesslich auch zu neuen Erkenntnissen - ich mag WB´s Fragen - nur nicht, wenn WB meine U2Us löscht und dann nochmal alles wissen will
Also - nicht rumstreiten - komm doch am 19.12. nach Leonberg, WB - da kann man alles viel einfacher direkt erklären, Fragen, fragen, fragen - den ganzen Mittag lang und sich nebenbei auf Weihnachten freuen )
Liebe Grüße und schön´s Wochenende
Alexander
PS.: WB - bei dem Conrad Bausatz - da muss man ALLES zusammenlöten - das ist lediglich eine Tüte voll mit IC´s (Chips - aber ungetunt), Widerständen, Kondensatoren, Potis etc. - macht aber richtig Spass, das zu löten, vor allem, wenn´s dann auch noch geht )
Suche CD Wechsler für E38 Bj. 12/97 mit DSP! KJ750IL Suche... 1 13.02.2006 20:20
Suche DSP Hutablagen soundblende NoDo Suche... 0 08.11.2004 02:33
Suche Pinbelegung von DSP Bedienteil 22SY300/23 Howy25 BMW 7er, Modell E38 0 02.12.2002 01:39
Pinbelegung DSP Einheit (ohne NAVI) Howy25 BMW 7er, Modell E38 0 18.10.2002 12:53
Alle Zeitangaben in WEZ +1. Es ist jetzt 23:13 Uhr.
