Modell F01/F02
 Modelle
Alt 07.06.2019, 12:19   #1
Mavve750
7er-fan.
Benutzerbild von Mavve750
Fahrzeug: E32 750iL(90), E38 750iL(2000), F02 760Li(2015)
Standard Nightvision nachrüsten, wo?
Where in Germany can I get the Nightvision retrofitted to my 760Li, 2014-10-01.
Sis können auch auf deutsch schreiben.
Thanks!
Mavve750 ist offline   Antwort Mit Zitat antworten
Alt 09.06.2019, 12:38   #2
ray_muc
Benutzerbild von ray_muc
Fahrzeug: diverses
hi
nightvision isn´t retrofit possible.
the nightvision camera is save combined with a fsc-code depending on the VIN of your car.
in deeper law it belongs to "war-weapons" like tanks, machineguns a.s.o...
sounds funky and not in relation but it´s the law.
i did retrofit a nightvision years ago having best contacts to BMW itself,
it´s not unpossible, but unpossible without vitamin B
hacks and cracks might exist, like all does in dark law areas, but i would keep hands off that shit.
at least you need to have a camera within a VIN and electronic device that belongs to your car vin.
it´s not possible to order a vincode fsc in aftersales process for your VIN on official way, cause it´s generated in factory order.
nightvision is war-material index,...
sorry, it is like it is...
best regards
ray
Geändert von ray_muc (09.06.2019 um 12:44 Uhr).
ray_muc ist offline   Antwort Mit Zitat antworten
Alt 09.06.2019, 15:01   #3
Mavve750
7er-fan.
I understand and thank you for your answer.
I drove directly to you just after I bought my car in München.
Some people, like yourself, has done it - and I will do it.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://www.bimmerfest.com/forums/sh.../topics/933281
Alt 10.06.2019, 10:08   #4
ray_muc
Fahrzeug: diverses
like i said, it is not impossible, but you need a hack for it.
main problem then is not to get it run, but after that your car wont be able to be programmed by any BMW Computer system again, thats what you should know about,...
and you need someone to write your "FA" - "custom-vehicle-letter" perfect to bring it up to work well with all other components in your car.
at least you should have the lates update version on the whole car before retrofitting, but keep also law in mind.
americans dont care, german law does
and !
i have had a lot of customers that had any of other retrofitting by using a "hack-simulator" and causing a lot of main problems killing the whole BUS-system.
these "hack-simulators" often get failure
best regards
Geändert von ray_muc (10.06.2019 um 10:45 Uhr).
Elektrik: NightVision nachrüsten intru BMW 7er, Modell E65/E66 47 01.06.2019 23:22
Nightvision gonzo007 BMW 7er, Modell F01/F02 1 29.06.2010 19:23
Nightvision Chewbacca1973 BMW 7er, Modell F01/F02 20 12.05.2010 08:23
F01 NightVision im Weihnachtstest... Alfred Tetzlaf BMW 7er, Modell F01/F02 6 02.01.2009 00:42
Wer hat schon Nightvision? oeki47 BMW 7er, Modell E65/E66 3 08.09.2005 11:39
Alle Zeitangaben in WEZ +2. Es ist jetzt 22:25 Uhr.
