![](layout/start02.jpg)
![](layout/whitepixel.gif)
![](layout/shadow.gif)
Modell F01/F02 |
![](http://www.7-forum.com/templates/images/f01klein.jpg) |
Modelle |
![](layout/start01.gif) |
![](layout/clearpixel.gif)
09.05.2010, 09:02
Fahrzeug: BMW 315 82, M3 E30 86
Two questions
Hi guys,
First of all the new car is absolutely superb ![Top!](images/smilies/top.gif) Its very quite, comfortable and fast as well. We drove 350 kilometers now.
But two questions:
1. We have DAB radio and the sound quality is very good, but sometimes when we listen to DAB radio the sound just stops for a few seconds and than continuous again. It does say no signal when it does it, but is there anything I can do to eliminate this problem?
2. Speedlimit info has disappeared. I have looked at setting -> info sources, according to the instruction booklet it should be there, but it isn´t. Anyone exprience with this?
Thanks,
09.05.2010, 11:51
That sounds to me like the typical difference between analog and digital. Analog gets worse and noisy if the signal gets weak, digital shuts off 100%.
What do you see? No sign at all any more or the red round sign with thre - - - signs in the middle of it?
Greetings to Malawi ;-)
09.05.2010, 12:04
Just nothing at all, it is completely gone. And I can´t find in anywhere in the Idrive system, Also not after reading the instruction booklet.
Greetings back from Lilongwe ![Blinzeln](images/smilies/wink.gif)
09.05.2010, 12:07
I'll translate it, perhaps somebody knows a solution.
Also sein Tempolimitschild bei der Tempolimiterkennung ist weg.
Es ist nicht inhaltsleer (wie oft nach dem Start) mit drei - - -
sondern es ist komplett weg.
Kann man das versehentlich deaktivieren oder ausblenden?
09.05.2010, 12:13
Fahrzeug: F02 730Ld 03.2012
Ja, wenn man sich zum Beispiel die Distanz bis zum Ziel anzeigen lässt. Einfach den Bordcomputer über den Blinkerhebel mal weiter durchdrücken.
09.05.2010, 12:26
Aber im HUD bleibt es doch trotzdem angezeigt?
09.05.2010, 13:20
Fahrzeug: Porsche 718 Cayman GTS, Opel Adam Rocks
Ja, wenn es im HUD Menü im iDrive eingestellt ist und das HUD aktiviert ist (linke Schalterleiste).
