Alt 03.06.2005, 03:27   #2
Standard Du hast keine Duesen mehr drin
wahrscheinlich abgefallen/-fahren an einer Bordsteinkante. Bist Du nicht der erste dem das passiert
Gibt einen alten Thread von mir und Nordberg, da ist darueber geschrieben. Gab mal eine tolle Anleitung von Lawson Garden aus dem U.K. register, leider tot. Aber hier mal eine Beschreibung. Vorab gesagt: Du brauchst Gummiarme, normalerweise geht man von der Motorraumseite. Aber hier mal eine andere Beschreibung, die mir besser erscheint. Gerade gefunden. Die Duesen haben Clips!, die in den Stosstangen stecken. Wenn Du da dran zuviel rumbiegst, brechen die Platikwinkel, und dann wird es noch schlimmer.
Fog light washer nozzle repair
Parts:
Fog Light Washer Jet – 61 67 1 378 616
O-Ring – 64 50 8 390 601
Wait until it is above freezing to attempt this job. There are some small plastic pieces in the washer system in the bumper that may become brittle in the cold and break.
Remove fog light: Pull off trim next to fog light. Pull on the side of the trim nearest the fog light to remove it. Remove top exposed Philips head screw (the bottom one adjusts fog light aim) and remove fog light.
Remove fog light mount bracket: This is attached on one side with two screws that face the car and a plastic ball joint on the other. Remove two screws and pull out ball joint.
You should be able to touch the jet and its mounting nut through the fog light hole. The jet is attached to the bumper with a 19mm hex plastic nut. Before loosening the nut, remove the “L” shaped fitting from the washer jet by pulling it straight up. It snaps on the washer jet fitting so you may need a little leverage to pop it off. All that’s left is to loosen the plastic nut and the washer nozzle will drop out. This is the hardest part of the whole job. First try to get a 19mm crescent wrench on the nut. If this doesn’t fit or the nut is in the wrong orientation, I used a small pair of vise grips. You only need to loosen it a little before you will be able to turn the nut with your fingers. Installation is the reverse of removal.
One risk with the job is that you may end up with a slow washer fluid leak (as I did). I am hoping it is slow enough that it may cure itself. The passenger side is harder than the driver’s side because there is less room with all the washer fluid lines in the bumper in that area.
Good luck,
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) klick
Geändert von Erich (03.06.2005 um 06:56 Uhr).
Wenn die Nebelscheinwerfer nicht mehr halten bzw. nicht rausgehen... CorpSpy E38: Tipps & Tricks 11 30.05.2006 18:05
suche nebelscheinwerfer e38 MikeLorey Suche... 3 25.03.2005 19:31
Suche Nebelscheinwerfer für E38 vo. Links Baddy Suche... 0 22.03.2005 10:49
Nebelscheinwerfer: Würde mich mal was interessieren! Schmelli BMW 7er, Modell E38 6 30.10.2002 10:05
Alle Zeitangaben in WEZ +1. Es ist jetzt 12:27 Uhr.
