Alt 16.11.2010, 15:20   #1
Sanyi
Fahrzeug: BMW 745i
Standard 745i Electric failure problem, drive moderately
So hello Guys,
I have some problem with my 2003 745i. The problem is:
I drive the car in the morning, the engine temperature is increasing, I got a red light, so I slow down, braking, and the cd restarting, the arrows of the gear are flashing, the idrive says that abs failure, drive and brakes problem, please drive moderately. The car do a small check, and the idle is increasing, like when you press start-stop button.. after 10 seconds, everything disappear, and the car is normal again.. but it do more quite often, and when the engine temperature is not reached the normal temp. I take the car to the BMW Service, and no fault code in the computer.... So they don't know, where to search the problem.. Any Suggestion?
BR,
Alex
Sanyi ist offline   Antwort Mit Zitat antworten
Alt 16.11.2010, 15:23   #2
Daniel
in process...
Benutzerbild von Daniel
Fahrzeug: BMW E61 535d (VFL)
How old is the battery?
This can be the solution, if it don´t work fine.
Gruß aus dem Sauerland
Daniel
Daniel ist offline   Antwort Mit Zitat antworten
Alt 16.11.2010, 16:20   #3
Sanyi
Fahrzeug: BMW 745i
It is 3 years old battery, original BMW battery... I'dont know.. No low voltage sign, or anything else...
Alt 16.11.2010, 19:07   #4
Daniel
in process...
Try to load it and watch the result.
Elektrik: electric troubleshooting manual Erich E32: Tipps & Tricks 3 13.02.2022 13:46
Motorraum: DISA Failure Ghibli BMW 7er, Modell E65/E66 5 09.06.2012 14:16
Elektrik: Electric and transmission petoch BMW 7er, Modell E32 5 13.04.2008 03:57
Elektrik: I-Drive Problem TobiasH BMW 7er, Modell E65/E66 9 29.06.2005 09:37
Alle Zeitangaben in WEZ +1. Es ist jetzt 00:05 Uhr.
