Alt 15.11.2010, 02:32   #1
Sanyi
Fahrzeug: BMW 745i
Standard Zweite Luft Pumpe und E46 glas kratzer (English)
Hello Guys,
I have a problem with my car. 1 year ago the secondary air pump was filled up with water... we thought that the pump was dead, that's why it was full with water. But 1 year later, today, I was at the service, and the new one was filled up also, and it was dead.... the pipe from/to this was also filled up with water... I don't know what is the problem... Any experience, or suggestion?
And...
I have some scratches on the side window on the driver side. It cramp me a little bit. What do you think, how can be repair these? I thought about the polishing, but I heard it is bad on the glasses on the car. Or anybody know that technology, which is good for these without changing the glass? ( I don't want glass distorsion, ohne " licht dellen") Has the polishing that kind of technology, which would be good for me? Or any suggestion?
Anybody recommend a good service in Austria or Germany, which can do this?
Best Regards,
Sanyi
Sanyi ist offline   Antwort Mit Zitat antworten
Alt 15.11.2010, 07:48   #2
andreas4
Benutzerbild von andreas4
Fahrzeug: 745i
If you can understand German, you should read the information on the following page:
Go to Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) www.ms-motor-service.com
->Onlineshop in the upper right
->Gastzugang
->select your car
-> read the information on
Sekundärluftpumpe
Sekundärluftventil
As far as I understand, they say that if you replace the secondary air pump, you should also replace or at least check the connected valves, because these valves ensure that the pump doesn't fill up with water.
The valves should be number 8 in this figure:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Emission control pipes BMW 7' E65, 745i (N62) ? BMW parts catalog
andreas4 ist offline   Antwort Mit Zitat antworten
Glas und Lackierarbeiten stehen an seba BMW 7er, Modell E32 3 27.01.2010 19:43
Waschstraße: Waschanlage und hinterher Kratzer im Lack Paule Fahrzeugpflege 6 30.12.2009 06:49
Glas Reperatur / Glas Wechsel Scheibenwechsel Pat_750i BMW Service. Werkstätten und mehr... 3 28.03.2009 22:47
Motorraum: Heizventile und Pumpe müssen die dort sitzen beim 750? Und eine frage! E32Neuling BMW 7er, Modell E32 23 14.09.2007 20:15
Alle Zeitangaben in WEZ +1. Es ist jetzt 07:57 Uhr.
