16.11.2010, 16:20
Fahrzeug: BMW 745i
745i Electric failure problem, drive moderately
So hello Guys,
I have some problem with my 2003 745i. The problem is:
I drive the car in the morning, the engine temperature is increasing, I got a red light, so I slow down, braking, and the cd restarting, the arrows of the gear are flashing, the idrive says that abs failure, drive and brakes problem, please drive moderately. The car do a small check, and the idle is increasing, like when you press start-stop button.. after 10 seconds, everything disappear, and the car is normal again.. but it do more quite often, and when the engine temperature is not reached the normal temp. I take the car to the BMW Service, and no fault code in the computer.... So they don't know, where to search the problem.. Any Suggestion?
BR,
Alex
16.11.2010, 16:23
in process...
Fahrzeug: BMW E61 535d (VFL)
How old is the battery?
This can be the solution, if it don´t work fine.
Gruß aus dem Sauerland
Daniel
16.11.2010, 17:20
Fahrzeug: BMW 745i
It is 3 years old battery, original BMW battery... I'dont know.. No low voltage sign, or anything else...
16.11.2010, 20:07
in process...
Try to load it and watch the result.
