Alt 12.01.2004, 10:14   #1
moriz202
Fahrzeug: BMW 730 d E65
Standard Navigation problem with dvd disc
Problem: I have professional navigation system (609) in my E65 (9/02). I bought a new dvd mapdisc, but it doesn´t work, the equipment pushes the disc out and command says "cant find cd disc". I tought that 609 professional navigation system should work also with dvds? Does dvd changer help in this case? (havent got any yet).
Thanks
Moriz
moriz202 ist offline   Antwort Mit Zitat antworten
Alt 12.01.2004, 12:21   #2
Chris Angle
früher: stolzer Besitzer
Benutzerbild von Chris Angle
Fahrzeug: E65 730d (Fertigungsdat.: März 2003)
Hello Moriz 202
As far as I know the dvd-navigation player has been bulit into the E65/66 in early 2003, not earlier. Just open the rear left side in the trunk, boot or motoring (I don't know what it is called in English: the area where you put your luggage) and look at the navigation player. If it does not read DVD-Navigation, then it is a CD Player only as the date of car-production suggests yet.
The DVD changer however will only play DVD-Video and CD-Audio, nothing else! So it isn't a solution for the navigation system.
The only possibilties for you is either to exchange the navigation-cd player for a navigation-dvd-player or to exchange the navigation-dvd for a navigation-cd which should be the cheaper solution for the moment.
Greetings from Germany
[Bearbeitet am 12.1.2004 um 12:41 von Chris Angle]
Weiterhin Dauerbaustellenbesitzer = enttäuscht-frustierter Besitzer
Chris Angle ist offline   Antwort Mit Zitat antworten
Alt 12.01.2004, 13:28   #3
moriz202
Thanks for the information!
Original geschrieben von Chris Angle
Hello Moriz 202
Alle Zeitangaben in WEZ +1. Es ist jetzt 18:43 Uhr.
