Alt 19.02.2023, 21:05   #1
Piramides31
Fahrzeug: E65-730D (09.02)
Standard cdc upgrade harness part number
Hello very good to this great family. and I thank you for letting me belong to this great forum. I introduce myself here I am from Spain and I have a very careful 2002 BMW 730D E65. i am installing the cd loader on the board. I already have the Cdc and I am looking for the cable harness that appears in EBA. Can someone please tell me the reference number of this cable. to be able to ask for it. forgive the inconvenience. I ask about this harness because looking at EBA it is different than the cable that came with the CD changer. because with the cd changer I got a harness that is made up of two optical fibers and three thin cables. I know that the optical fibers are connected in line with the MOST in the glove box but my question is ???? where these three thin cables connect to??? any help please. I thought that they connect to the black connector of the idriver screen. but I'm not sure if it's correct and I also don't know what number of pins it would connect to. Thank you all. receive a warm greeting
Piramides31 ist offline   Antwort Mit Zitat antworten
Alt 21.02.2023, 13:41   #2
j_ramon.lopez
Fahrzeug: E65 740i Bj 05/2007
I checked various pages but could not find any parts list of the retrofit kit for CD changer.
As far as I could see in this instructions that the set comes with all needed parts but no further informations about the part number of the retrofit cable.
Maybe this link helps you a bit further:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://bmw.etk.club/eba_docs/5546en.pdf
j_ramon.lopez ist offline   Antwort Mit Zitat antworten
Alt 21.02.2023, 15:00   #3
Markus525iT
Part number for the wiring harness is 61 12 0 142 348
Best regards
Markus
Alt 21.02.2023, 15:23   #4
Piramides31
Daumen nach oben Hello gentleman
Thank you very much for your help and for your answer. You receive a warm greeting. a hug from Spain.
Alt 21.02.2023, 15:20   #5
Piramides31
Top! Hello my friend
thanks a lot. I'm really grateful to you. a greeting from Spain.
Getriebe: 750 end bearing part number Erlingur BMW 7er, Modell E32 2 23.01.2009 09:13
VIN (Vehicle Identification Number) Dirk_122 BMW 7er, Modell E38 13 16.02.2006 12:44
trying to find part number for water hose Petri BMW 7er, Modell E23 1 20.05.2005 09:18
On Board Monitor wire harness connectors needed jcarey BMW 7er, Modell E38 1 17.04.2004 09:32
Alle Zeitangaben in WEZ +1. Es ist jetzt 02:28 Uhr.
